EdBwoy »
https://forums.nicoclub.com/edbwoy-u213758.html
Tue Jan 05, 2016 9:00 pm
Well, in all all the other Nissans I had, I really did not do anything about it. I think the valve lifter designs on most Nissans are such that they give good performance, but sacrifice in the noise-at-cold-startup department.
However, this 06 M45 that I was talking about ended up throwing a rod "suddenly". I put that in quotes because this engine, like many I had, made some noise when cold. Looking back at the videos I recorded, it seems like I should have caught this earlier on.
As you could imagine, with gravity, engines will drain their oil to the lower compartment. Let them sit for too long and the upper compartments are sort of "dry". To me, this explains why our engines make such a racket at startup if they've been sitting too long.
The second part (and I really have to study the oil path to confirm this theory) is due to oil draining from the top and pooling in the cylinders. After a long hiatus, it means your initial combustion includes a decent amount of oil to cause your blue smoke.
Here's a catch. The V8s in the 06+ M45s as well as some Fx45s seem to have oil issues. These lead to rod bearing issues and make a different kind of sound than lifter tick. I have a lot of youtube videos and forum threads that I have been referring to when trying to diagnose these issues, as well as 2 personal incidences of damaged engines.
Concise answer: No, I haven't tried oil additives to cure the noise, but I have used seafoam to get rid of carbon build up. If you can, post a video of your engine exhibiting the noise and we can do our best to tell you if you should be concerned.
Also, give us some history on the car.
