Hey folks, I just picked up a questionable, but too cheap to pass up, 2003 Pathfinder. It's been sitting for not more than a year. A mechanic was paid to install a used engine, and it hasn't been used since. No paperwork on the engine replacement. It's a 2wd, but it has a 4wd cluster which shows 218k miles. Maybe that's the cluster from the donor? Who knows. It runs and drives good except for an RPM issue. No smoke. It does have an exhaust leak on the passenger side somewhere near the manifold. It's in overall good condition with very good Yokohama tires, and I drove it home for $500. The issue is that the RPMs will only go high if the accelerator is pressed slowly. It'll rev up to 5000 and probably more in park if pressed slowly. But in park or driving if the accelerator is quickly floored, or if while driving you try to accelerate at a rate needed for merging onto a highway, it cuts out. Sort of like a rev limiter I guess, in that it'll rev, drop, rev, drop, etc. but the cycle isn't as fast as what you'd hear in a performance car. It'll stop doing that if I let off the pedal and then will accelerate slowly if I press it back down slowly. I don't think it's in limp mode because speed isn't limited, I got up to 50 or so on the drive home. Do y'all have any ideas of where to begin to check? Thanks in advance for any advice.
