emm3seven wrote: ↑Sat Jul 23, 2022 8:01 am
What symptoms caused you to replace so many of the front end components? Chasing some clunks in my front end on my 2011, curious what you found.
I ended up doing everything. First thing I noticed was degraded ride and some weird noises. Struts first then. Found a shop willing to rebuild them which saved a bunch. Can't thank that shop enough.
Eliminating that revealed steering darting. Or things just degraded on their own in that time.
At any rate, tie rods and upper control arms were next. I didn't do lowers at the same time because they are silly expensive and can't be rebuilt.
Then I developed a power steering fluid leak. Replaced the rack with a reman and got burnt. That rack is marginal at best. Although still installed, it's not going to make 25K miles and be replaced. But for now, it just makes a little noise.
But, that bad rack caused additional pressure on the pump and that has now been replaced as well.
So at this point, pretty much everything in the front end has been replaced.
The lower control arms are on order as well. I figure I better replace them before they lead to wearing on something I've already fixed.
I big part of the problem was Southern Ontario winters and the salt used. The original owner did not Rust Check the car which would have delayed much of this pain. Such is life. I don't regret a penny I've put into this car.
