euroboy »
https://forums.nicoclub.com/euroboy-u12971.html
Tue Sep 07, 2004 3:11 am
actually i fixed that and i saw a major leak in the system. Once that was fixed too i took the car for a spin.It revved fine, it idled pretty good...so after warming it up with the ca18et maf WHICH ARE the samei boosted to 9 pound...
well i let go of the gas and now the car has a lot of trouble iddling. It's even worse than before, a lot of popping, it sounds like it's going to die at idle. I play with the throttle it misfires but eventually it picks up on the revs. I let go of the throttle the car dies and idles at 300rpm area. I can't see eny thing wrong with it as far as leaks go. Dunno if the fuel pump gave way, but there is spark on all 4 cylinders. The coils are good as well 2.8 OM of resistance. I can't see any leaks, and if it was a foulty MAF it wouldn't rev past 2k.
ps: ca18det and ca18et 87 have the same maf set up. Same size, 4 wire plug.
