90240sxca18 wrote:so i compression tested my motor when it was out of my car
#1-140#2-135#3-135#4-145#5-135#6-140
the motor in my car ran extremely rich. it was stock rb20 with rb25 turbo, untuned. ran rich as ****t!! black smoke stained on the walls in the shop, fireballs all the time. completely black sparkplugs.. shooting liguid out the exhaust. with previous owner on a tune with a safc it made 232whp n 216 lb-ft of torque.
yesterday i trade my rb25 turbo, stock manifold, smic,intake manifold. for a top mount xs power manifold with a t3 flange, hks fmic with piping, log intake plenum manifold, sc61 precession turbo, and a safc. i was wonder if my rings possible shoudl be replaced or should i do a rebuild before i put the turbo on n run 12lbs 280 whp + i was juts going to order arp headstuds and a head gasket and rb26 cams. but people on my local forum said that the rings are about to go and i need a rebuild.. hellppp
you are more concern when there's a drastic difference between the cylinders. but yours are pretty even on all 6, so wouldn't worry about a rebuild. are you still running on the stock headgasket? some aftermarket headgasket will lower your base/static compression.
it is proper to run the engine to operating temperature, and then do the compression test while WOT
