New turbo is on its way
kzoosho
Car: Turboed 1997 Nissan Maxima SE
Theres me trying to pick up the motor.
Clutch is on.
Check out how many splines there is.
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
How much more hp are hoping to gain?
kzoosho
Almost double what I made last year.
tigersharkdude
Car: 1999 Nissan Maxima
kzoosoo, a few questions and comments1.) THAT TURBO IF ****ING HUGE 2.) whats up with the hood, i like it. can you make me one??3.) did that front bumper fit good??4.) loving the fogs
your max is gonna be awesome when done. one of the best 4th gens
Modified by tigersharkdude at 7:26 PM 9/25/2009
kzoosho
tigersharkdude wrote:kzoosoo, a few questions and comments1.) THAT TURBO IF ****ING HUGE 2.) whats up with the hood, i like it. can you make me one??3.) did that front bumper fit good??4.) loving the fogs
That is a CF hood that i cut to make my manifold fit. It can be made again with a little time. The front bumper fit better than my r33 bumper i had last year. The fogs are Hella RS6 projectors with 3000k bulbs. I hope to be able to see. I have TL low beams, E55 high beams, and RS6 fogs. I think i have the lighting covered.
kzoosho
tigersharkdude
dang man where you been? everyone has been wondering
kzoosho
Jail my friend. Im out now lol.
tigersharkdude
that sucks
Presscott707
Car: 1999 Maxima 5spd
sorry to here about you getting locked up and all bro, that sucks. The car looks like its coming along great man. the lights, hood and new bumper look great im sort of jealous, my car looks like crap now. Good s*** bro
kzoosho
tigersharkdude
any idea what its gonna be putting down when you get done
kzoosho
Im shooting for mid 600's when all said and done.
tigersharkdude
Holy **** dude
kzoosho
Lol right. its pointless, useless, retarded, but no ones done it yet lol. Ima start breaking stuff and fast but it will be all done in fun.
FIEND
Car: 1995 Nissan Maxima GLE
Props man!!!
NutriaforBreakfast
Car: Nissan Maxima 1995 VQDE engine
Did you pull the motor? If so was it from the top or underneath?Did you pull the transmission at the same time or did you undo it first?What brand of equipment do you recommend for pulling theengine and an engine stand?
kzoosho
Im a little special lol. When i took everything out, i dropped it out the bottom. When i put it in i went thru the top. I removed both motor and transmission at the same time but could have done either. I personally have harbor freight tools i.e engine hoist and all my air tools. i have never had a problem with them. no need to spend 20 times as much if they get the job done.
Presscott707
What are you using as far as internals to handle all that power and did you get the transmission built? What cv shafts are you using and my last question is what do you have done to the heads if you dont mind me asking.
kzoosho
Wiseco pistons, Eagle Rods, Cometic HG, ARP head studs, Bored also. As far as heads 350z Rev up springs, Valves, A lil head work also that i wont disclose yet lol.
transmission is a Stock 6 sp with oe axles for now.
Presscott707
top secret head work huh LOL J/k. have you looked at http://www.driveshaftshop.com for your axles, you should give them a try if you havnt already looked at them.
kzoosho
Presscott707 wrote:top secret head work huh LOL J/k. have you looked at http://www.driveshaftshop.com for your axles, you should give them a try if you havnt already looked at them.
Holy s*** bro, 1300 for a set of axles? i mean im no cheap a** but damn thats is kinda crazy
tigersharkdude
raxles axles FTMFW
Presscott707
dam i didnt know they were that much, my bad. i was going off of my home boys b18 axles.
NutriaforBreakfast
So you took the motor and trans out from the bottom. How didyou get the car up high enough to get them out from under thecar? Did you have to jack it up-put lumber or bricks under it- use jackstands-jack it up again etc.?
kzoosho
I jacked it up one side at a time and used jack stands. You can get the front pretty damn high.U can see how high i got it.
NutriaforBreakfast
Thanks for the pics! Looks like no jackstands on the rear part of thecar from what I see? I assume you removed the exhaust sytem before jacking it up so you would have more clearance?
I would be worried about both CV axles coming out at the same time.Are you putting dummy axles in to keep the transmission from losingits synchonization?
kzoosho
no jack stands on the rear . if you want more clearance you can remove the rear tires to sit the rear down as well. As for the transmission, i removed everything and not worried about messing anything up. I did not remove the exhuast at all, its still there. I unbolted it once it was lifted tho.
Presscott707
dam bro that was a pretty good way of doing it. i was thinking that you used a lift to do it.
240SXcoupeRB25
Car: nissan 240sx
keep up the good work.keep us posted on your ride homie
