AllTypes »
https://forums.nicoclub.com/alltypes-u56285.html
Tue Oct 23, 2007 5:34 pm
Hey guys I got a new Tuner system called NIStunes. This is a system that has been tested it seem to have a great tuning option that is promising. We will be trying this new system on a SR20det redtop engine which is stock. Ill keep you guys up dated
NIStune uses emulators or one daughterboard along with specialized software to provide tuning capabilities including map tracing and real time editing of maps, constants and tables for your Nissan ECU. All changes are made in real time so you can feel the engine change and watch the outputs from the all sensors while adjustments are made.There is three levels of for different type of Nissan ECU
NIStune Type 1 Board
Type 1 boards cover the following earlier non-consult vehicles:CR31 Skyline (RB30E)VL Commodore (RB30E)VL Turbo Commodore (RB30ET)Z31 300ZX (VG30E, VG30ET) 1984-1985, 1986, 1987-1989A31 Cefiro (RB20DET)J30 Maxima (VG30E)S12 Gazelle (CA18)S13 Silvia (CA18)S13 Stanza (KA24E)N12 Pulsar Exa (E15ET)N13 Pulsar (CA18DE)This is a first for older non-consult ECUs! You can now view and log RPM, Speed, AFM voltage, O2 sensor, Temperature, Battery, Timing and various switch settings. Diagnostic Terminal Codes can monitored and cleared. You can also perform real time tuning with this board!This board along with the NIStune software provides consult capabilities (including Diagnostic reporting) and maptracing for non-consult Nissan ECUs NIStune Type 2 Boards Type 2 boards cover the following earlier consult vehicles:
M30 Infiniti (VG30DE)Z32 Fairlady 300ZX (VG30DETT)HCR32 Skyline (RB20DET)BNR32 Skyline (RB26DETT)U12 Bluebird (KA24E)NIStune uses a daughterboard as an alternative to an emulator or EPROM chip for realtime tuning using a modified version of Nissan Consult. It provides faster transfer rates, realtime modification of maps, constants and tables using the NIStune software.
NIStune Type 3 Boards Type 3 boards cover the following earlier consult vehicles:S13 180SX (SR20DET)S13 Silvia (SR20DE,DET)S13 240SX (KA24DE)U13 Bluebird (SR20DET)B13 Sentra (SR20DE)S14 Silvia (SR20DET) [early model]N14 Pulsar (SR18DE, SR20DE)RNN14 Pulsar (SR20DET)Z32 Fairlady 300ZX (VG30DETT) [Late model] NIStune uses a daughterboard for realtime tuning using a modified version of Nissan Consult. It provides faster transfer rates, realtime modification of maps, constants and tables using the NIStune software.Emulation (Intronics Romulator / Moates Ostrich)
For those who wish to use emulation instead of built in boards
Using a single emulator will allow you to realtime tune your 8-bit ECU board using the Consult for ECU status and accurate maptracing. Note that some older ECUs do not have native Consult support and require a Type 1 board.Note: Just ordered a Moates V2.0 emulator which provides hardware (4 cell) maptracing! We will be adding this soon into NIStuneNote: You can use your existing Zemulator romualtor with consult for accurate maptracing and more features, including AFR overlaying! Using dual emulators combined with a commercially available daughterboard for 16-bit ECUs using Consult for ECU status and accurate maptracing. Emulation (CalumSult RealTime Board)We can confirm that NIStune software is now compatible with CalumSult realtime boards. This means that you no longer have to use three separate programs to emulate, datalog, maptrace and read wideband readings on. NIStune integrates all the data together in one package and can display and datalog all information together.
Any questions PM me
