new truck=need HELP!!!
silveradobeast
Car: 94 HARDBODY 2.4 5 SPEED
94 d21 5 SPEED 4X4 EXT CAB
PARTINNG OUT A D21
so ive been looking for a HB that is 4x4 ext and also 5 speed found one but the motor is bad its a 94 v6 5 sp the good news is that i have a donor truck that is extlactly the same but auto i got them both to make one, same color same year..
heres my Qs
i want a good aftermarket clutch any brands?
anything i should do while the motor is out?
IM ALSO PARTING OUT ONE OF THEM..
THANKS...
longtooth
Car: 89 d21 HB
Rear main seal. With a clutch you get what you paid for. Cheap is cheap. Haynes or centerforce are good clutches.
silveradobeast
PARTINNG OUT A D21
longtooth wrote:Rear main seal. With a clutch you get what you paid for. Cheap is cheap. Haynes or centerforce are good clutches.
yea not going for cheap at all, il look in to it!
thanks!!
RT22
Car: 1991 nissan hardbody
while it is out replace any hard to get to part like he said rear main seal. Any sensors that are buried, also that avoids running issues, and all and I mean ALL vacuum lines. Any hard to get to part is just a breeze when motor is out, also take time and clean everything like engine bay and motor so it looks better when in. With the hassle of swap might as well take a little time and money and do it right.
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
OEM clutches are as good as any. I'd stick with that.
While the engine is out, I'd do the timing belt, pulleys, water pump, and all belts/hoses. Also check for cracked exhaust manifolds.
Also do the plugs. That #6 plug will be a LOT easier with the engine out of the truck.
silveradobeast
PARTINNG OUT A D21
Desert Rat wrote:OEM clutches are as good as any. I'd stick with that.
will do thanks for the advive!!
