merlinq2 »
https://forums.nicoclub.com/merlinq2-u171090.html
Wed Jun 05, 2013 1:17 pm
I cannot speak to the fact that tires need to properly positioned in terms of the where the tires are on the car. I have had many tire rotations and have never noticed that the shop(infiniti) ever re set the sensors due to the new tire positions.
Before I replaced the sensors, I had only one wheel that was coming up as **, so that tells me that the system reads the sensor not matter which position it sits on the car. The warning told me it was the right rear; during the rotation this tire was placed on the drivers front, about 20 min later the ** showed up on the drivers front.
I am not an expert- the transmitters are in the wheels and the receivers are in the wheel wells, so the receivers will pick up the transmitter – when the system is armed and in read mode. So while the tires may not show the correct position on your display they will warn you of a low pressure condition; the issue is you will need to check all four tires. My issue and warning light was a function of a dead battery, the life span of the battery is about 4.5 to 5 years, one of mine was dead and I had to replace all four.
Found this on another forum:
Directly from the M45 Service Manual, "Immediately after a spare tire is mounted, a wheel is replaced or tire rotation is performed, tire pressure will not be indicated on the display and low tire pressure warning will not function. Reset the system by driving the vehicle at over 25MPH for approximately 10 minutes" (4-9)
However, whenever I rotate the tires, the TPMS never works and the dealer has to reset it but free of charge because I read them the above text. It is not my fault that the TPMS does not reset, why should I pay for it.
