New TPMS sensor still not registering
Matty1991
Car: 2012 Infiniti M35h
Hello everyone! M35H TPMS issue. I have had a blinking TPMS light issue for about a month now. The light blinks for about a minute then stays on. The car reads 3 out of the 4 sensors. I have had the bad sensor replaced today and it reads perfect on the machine but not in the car, all I get is ** the other 3 sensors work within 10 yards of moving off. What else should I be checking? Thank you!
Reason: Revise Title
Ilya
Is it an OEM sensor? Not all sensors are applicable to the car...
Matty1991
Not to sure, what about if I swap the wheels should the problem follow the wheel if it is a sensor issue? I'm just trying to pin point the issue here.
Ilya
Matty1991 wrote:
Tue Dec 19, 2023 6:54 am
Yes, if you rotate the wheels the problem should follow. It may take like 10 minutes at 60mph or whatever the 'secret sauce' is but eventually you should know. I had an issue years ago where I bought TPMS for another Nissan that didn't work with my car.
Matty1991
Ilya wrote:
Tue Dec 19, 2023 11:37 am
Thanks! I will rotate tyres after Xmas to see if it's the sensor fault or something more complicated!
asianhawaiian
Car: 2011 Infiniti M56x
Question on the new sensor did you have it programmed to match the old sensor?
