Still have the cooling system pressure test kit on the way later this week...
The only time I see it on the ground is when it pushes out the overflow resevoir (which only happens on a hot day with the A/C on)... I smell it sometimes but that could be the overflow... After a run to work today I used the thermometer on most of the engine, water hoses, radiator, etc and the only parts I could find over 180f was the exhaust... It has never heated up or shown any signs of overheating...EdBwoy wrote:That infrared camera is a Swiss army knife for diagnosis. Dragging brakes, transmission fluid changes, A/C diagnosis, checking windows & insulation in the house, body temperature etc...
Is the coolant not hitting the ground? If not, then it's either being "eaten" or dripping onto a hot component like the headers (but you'd smell it if it were external)
My drive to work is 20 minutes down the highway & No drips at all...atraudes wrote:Your water pump is behind the timing cover and is driven by the timing chain (no belt). I'm not sure where you'd look to see if it's leaking or not, other than removing the small access panel on the timing cover. Check the FSM to see what I mean and determine which one it is.
Is it possible it's only leaking while you're driving? Have you tried running the engine for 10-15 minutes after a drive to see if you can see it dripping anywhere? I'd imagine you'd see it after parking but not necessarily.
