In the thirteen years I've been into Z31s, I've yet to see anyone actually do this swap. The only Z31 cars I've seen with the VG30DETT are in Japan.billcannon791 wrote:Hi, I am looking for info on puting a VG30DETT form a 89-94 Z32 into a 86 Z31,question is will it work with out a lot of real major work, it is m first Z car and motor is locked up in it and so a engine swap would be good.Thanks for any and all help.Bill Cannon
crossmember: yes.harness: nomas/maf/afm: noecu: yesrelocate alt: only 84-86evildky wrote:the VG30ET si a bolt in but you gotta have the engine crossmsmber as well as the harness mas and ecu, and you'll have to relocate the alt to the passanger side, it's much easier if you can locate a wrecked donor car and just swap everything over
The MAS changed in 1987 and became a little more "precise". But the part numbers are the same for NA and turbo. Looking at the different FSMs, the actual variance at given loads got narrowed.evildky wrote:they use the same mas? and the n/a has a knock sensor? when I swapped my 86t into an 87 n/a a few months ago I went megasquirt so I didn't use any of the stock electronic's or wiring
if you're not experienced with these kinds of swaps you're better off getting a donor car
May I suggest you read this information:http://auto.howstuffworks.com/turbo.htmbillcannon791 wrote:That was some good reading from redz31.com, do all turbos need a wastegate and also what is it for?this will be my first so I would like to have it set up right the first time, thanks everyone
