New to us Amanda Le
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
MiniTank
Car: 2004 Nissan Pathfinder Armada LE
We just bought an 04 armada LE with 155,000 on it. There is some things I need to get fixed on it. I'm still trying to us the search on here so bear with me. Lol there is a beeping when I hit some bumps on the highway.
Problems:
Like the back up assist is beeping at me.
When I fill the tank up it only goes to 3/4 of a tank when full?
^^ heard it needs a fuel sending unit replaced
other than that not much wrong with the vehicle.
Would also like to know if I can put a factory dvd player in it with minimal work as my 6 year old daughter is sad it doesn't have one. Lol
thanks for looking.
marctronixx
the backup alarm sounding as you go over bumps is a tough one.
in regards to the tank,
could be a faulty sender, could be evap canister. the fuel send unit is in the tank itself.
others things to smoke over:
brake rotors are smaller in the first run model
more plastic in the interior so you may hear some creaks in the interior.
manifolds may be cracked. check to see if they were ever replaced.
dont bother with a factory dvd player. it will be too much money to install a factory dvd player. recommend to go aftermarket. there are many many options out there and are not expensive at all. you can use ipads or one big drop down monitor for the back seat guests.
MiniTank
Thanks and is there a nice brake swap I can do? I'll be researching myself also.
marctronixx
tons of info on the net if you want to go aftermarket. i recommend the stock brake shoes as they are low dust and really perform well.
Return to “Armada Forum / QX56 Forum / QX80 Forum”
