New to this Forum, info about my car and a few pics
A forum for owners and fans of the legendary Nissan Skyline and Nissan GTR.
edthemanjp
Car: 1992 Skyline GTR
I've been on the Freshalloy forum for some time and I recognize some of the names over here. I'll introduce myself. I own a 1992 Nissan Skyline GTR that I purchased from a Plastic Surgeon on Okinawa. He had to sell this car because he'd just bought one of only 400 made, special edition STI and didn't have the parking space allocated for this car. I got a great deal. I imported this car through Motorex in Feb 2004, this is my retirement gift from the military from my family. I picked up my car from CA in Feb 2006 after having to pay a high priced lawyer to get it back. Through this process I learned more about the import process than I really wanted to know and I also met some good people and some bad people.
I have added a list of current mods and a few pics enjoy
Engine modifications• Bored 40 over• Wiseco Skirted 87mm pistons• Corilla Rods with ARP bolts• Polished and balanced Crank• Cosworth bearings• ATI damper• Long block balanced • N1 oil pump• N1 water pump• Bullion high flow 65degree Celsius thermostat• Nismo timing belt• Apexi cams 266 9.0 intake 268 9.0 exhaust• HKS step 2 springs• Cometic head gasket• HKS 2530 turbines• HKS down pipes• Z32 MAFs w/Apexi intakes• RSR front pipe 70mmX2 80mm• HKS Silencer exhaust• Sard 720 injectors• Nismo fuel regulator• Nismo engine mounts• Nismo Transmission mount• Z32 fuel filter
Engine management modifications• Apexi PFC L Jetro with Data-logit• Blitz Dual SBCR boost controller• AEM AFR• Greddy boost meter with memory function
Drive train modifications• OS twin TS2DB metal clutch• Route 6 Xmission (close ratio)• Transmission member spacers• ATS 2 way rear Diff• Steel braided one piece clutch line• T.S. Dancer torque split controller• TSP torque split controller from England
Suspension modifications• Nismo Rear upper link• Nismo rear A arm• Nismo front upper link• Nismo front tension rods• Kayaba New SR special shocks• DOW MAX digital springs
Brake Modifications• R33 GTR Brembo brakes and rotors• Steel braided lines• Cusco master cylinder brake brace bar
Body modifications• Inner fender brace/ A pillar brace• Cusco strut braces front and rear• Kansai lower brace bar set• Nismo front under strut brace bar
Other modifications• Rear steer (HICAS) solenoids removed• HICAS canceller installed• A/C removed (all)• Power steering reservoir moved.
Items waiting to go on• Sard fuel regulator• Tomei fuel rail• Russell steel braided lines and fittings• HKS 3 core GT Hybrid intercooler
bone_stock_240
Car: 1995 Infiniti Q45
Wow, that car sounds beastly. Welcome to the club!
Encryptshun
Car: 2005 Nissan Xterra
Welcome, thank you for protecting our country, and damn nice ride.
Quick question, though -- why did you decide to go non-hicas?
002-M-P
Car: Z33-RB26 IP
Seen you on freshalloy alot....Never knew your car had such an extensive mod list. Nice.
BOOMSHAKALAKA
Awesome ride you have there...welcome and thanks for your service.
ImportExport
Car: R34 GTT - S15 Spec R *For sale*
props
edthemanjp
The rear steer is not much of an added benefit its on below 70km. Some people have said it also comes on after 160km, I've read nothing about this and if it did this is not something I would want to break or not function properly at those speeds. Since I won't be using it I've removed it
Return to “GTR Forum / Skyline Forum”
