Jessed518 wrote: any info would be appreciated, thanks!
Basic tunes are a good starting point, and tend to err on the side of richness for safety. JWT, SpecialtyZ, and Ztuner have the best ECU upgrades for our cars. Once you get the ECU socketed, you can switch the EPROM (chip) whenever you like. From there you can add a SAFC and do your own AFR fine tuning.
A custom tune from a tuner, SpecialtyZ (cali) or Ztuner (florida) is your best bet without getting too heavy into the tuning of things.
To DIY with maximum flexibility without going to a standalone, get the product known as NISTune. It allows you to change all the parameters in your ECU with a laptop.
You're right about the closed-loop air/fuel system the Z32 uses. Air is measured through the MAF, fuel is added accordingly, O2s are read, fuel is adjusted etc etc. But like I said, basic tunes, even from JWT and SZ and the like are meant for general applications, and not tuned to your specific car.
