4th_Gen_SE »
https://forums.nicoclub.com/4th-gen-se-u209748.html
Sun Sep 16, 2012 7:46 pm
Oh well, i'll post the rest tomorrow. The short story is: It's an N/A, 5spd, slick top that's costing me $2000 exactly. Problem the oil pump has gone out. I think that its the oil pump because when I test drove it for a bit the oil pressure gauge never got relatively close to even 10psi at idle, or hard throttle. Also after the engine warmed up grayish smoke started pouring from under the engine bay. No funny colored, milky, or thin oil. It was full of coolant, didn't run hot, no CELs, idles and drives great (albeit very course). So i'm gonna change the oil pan and pump, flush the engine with that gallon of Z cleaner (I forget the name) and do the routine stuff, Timing belt, plugs, packs as needed...Sound anything else I should check for?
