Thanks for the suggestions! Im not claiming my friend to be a expert on this car, just someone with an idea. I have checked most of the items on your list, just not the vacuum hoses which i will do! However, I just replaced the CAS (not without a hassle i might add, what a b**** to get out. Ended up using an air chisel and busted it apart pretty much) and it runs ten times better. No sputtering on takeoff, power band seems strong, really a huge improvement. I feel like it still may have a slight misfire on idle but i haven't determined that for sure, I'm just saying that based on what i hear from the exhaust. There still is a big charging issue, it seems to die directly after a jump repeatedly, but at random. Its been holding a charge all this week (but with low voltage) but won't stay running today. One problem down, on to the next.DCaff300ZX wrote:The CAS is an easy check and if working, would not need replacing...I'm surprised your "Nissan tech" has you buying parts without a reason, as that's the REALLY expensive way to fix a Z.
If the injectors are ohming out at the correct amount and all connectors to injectors are clean, then I'd be looking towards the CTS and those connections, and spark plug connections. If no improvement, I'd then look to the PTU and especially the harness, known for green residue and bad connections. No go, then I'd start thinking about vacuum leaks, checking all vacuum hoses and the PCV hoses for cracks/deterioration- very common. Another area of concern is the IACV (idle control valve) and hoses. If you make it that far and have ran codes and get none and still have a problem, then you will know that enough of the important systems are clean and working, and Consult or other scan testing will then have a basis to work from, and not a bunch of corrosion/wear possibilities with the areas I just went over.
Check back with us when you can report back exactly what you get in these areas and we can help a LOT more...
Great suggestions, thank you. We'll see if i have time to check out that stuff tonight. I do have a battery charger, so i could pull the terminals off and charge the battery completely too. just to see what happens with a fully charge battery i guess im saying.RubyRed300ZX wrote:Dead Battery issue (or in your words, holding a charge): 1) make sure the terminals are clean. (2) make sure the battery has water. (3)make sure the battery ground wire to the body and engine are clean and secure. (4) Check the fuseable link (black rectangular box next to the battery and the cruise control pod) which is a blue wire in the furthest left hand (passenger side) slot. Pull the fuseable link and look for green corrosion in the connection slots.If green, clean the hell out of it. (5) with the battery cables disconnected from the battery, check for continuity from the alternator to the disconnected positive battery cable connector.
If all is good for the above, then have the battery checked to see if your battery is good. If that is good, then unfortunately you may have to pull the alternator to have it checked. The engine always runs off the battery. The alternator recharges the battery. So if you put a digital meter onto the battery, without the car running, you should see around 12 volts. Then start the car, and you should see it reading around 14.86 volts. The fact that your car dies almost immediately after disconnecting the jumper cables would seem to imply that the alternator is not getting a charge back up to the dead battery. Hence, the steps above to isolate the problem. A fully charged battery should allow the car to run for about 20 minutes without the alternator.
Pretty much all the wisdom I can offer. Check back with us to let us know what you found.
