This weekend I'll be having my first ever Nissan Delivered!
Car-
1986 Nissan 300ZX NA (non turbo) MT
2+0 seat configuration
( I'm asking for clarification, but NA is for non turbo correct?)
Found this at my GF's uncles house, sitting out front unmolested, as far as i can tell.
He'll be the one delivering it this Saturday, gave it to me for 1000 USD, so not bad i don't think
The cons-
the interior isn't completely wrecked, but could use some work, door panels and seats specifically.
Will mostly likely need the T-top seals, haven't seen it in water yet but couldn't find any water damage inside, he said it'd been there for almost 2 yrs uncovered
Sounds like a misfire, but his son had done the wires and plugs, so I'm guessing its a simple fix there...hoping...
clutch stick a little when depresses, assuming it needs bleeding or some WD40 on the pedal
Chrome on rims is peeling in the tire bead creating an air leak, hence the flat rear (will be sand blasting and blacking out)
the pros-
paint looks good, no serious scratches
the headlamps flip, and all lights work thus far
fires up a little rough from sitting, and weak battery
shifts through all gears while sitting
other than that, the dash works, it has the fancy digital one *so much future*, but I couldn't check the tach or speed on it, given its current standing
New tires as of 6 MO's ago
I am pretty mechanically savvy, this will be my first Nissan, RWD, and 6cyl though.
Don't know if it's a bad word around these parts but i was born into mechanics via *wispers* Honda
Any and all tune up, fluid recommendations, general maintenance tip are greatly appreciated
I'm extremely excited for this vehicle, and learning more about it, as well as keeping my hands wrist deep into it.
