afracer »
https://forums.nicoclub.com/afracer-u10107.html
Mon Jan 30, 2006 7:10 pm
Thanks guys, I try hard to keep it clean and simple. The pig nose wasn't by any means my idea, I usually prefer the newer style actually. The car was at some point in it's past in a pretty bad wreck and they pulled almost the entire front end off a banged up pig nose 240SX that was formerly red and patched and painted it up cheaply to see what you have here. Convertibles as far as I know never came with the pig nose ('91+) and I liked the idea of cutting out the noses for more airflow to the radiator/intercooler, so I left it there for now. I'd like to piece together a OEM Kouki front bumper for it later on, it'd be easy to throw an aftermarket on there but I don't care for crack-prone FRP. Unfortunately the spoiler and sideskirts I don't have much choice on that, but bumpers, hoods, and main body parts I like to keep OEM for strength and durability. I also plan on getting some non-bondo'd fenders and throwing on some coupe doors, a roll bar, Bomex rear under spoiler, and some race harnesses at some point in the future.
I've been driving it for a month now with the SR and despite needing a little more tuning it got up to 29 mpg's and might have hit ~137 mph recently on a deserted highway as well
The engine swap is about as clean as it can get here's the mods:
Redtop SR w/60,000 milesJet Hot coated SSAC manifoldS15 turbine @ 1.2 barZ32 MAFSRetuned ECU by Scott @ Stec550 injectors/255lph pump/Nismo FPRGreddy outlet, full stainless 80mm exhaust w/test pipeHKS Power Flow intakeHKS SSQVBlitz DSBC Spec RRPS Max Street ClutchBillet Steel 11lb flywheel29x12x3 bar and plate FMIC2.5" Stainless I/C pipingS13 2 way LSD (unknown make)JDM front brakes/sway barsTanabe Sustec Pro coilovers with pillow ball uppers all aroundTanabe Camber plates, pillow ball T/C rods, full pillow ball/adj. rear suspension (traction rods, upper control arms, etc)
There's more stuff but none of it's really important compared to the aforementioned items. This car is my daily driver so unless I blow the turbine sometime soon or break something, near future plans will be fine tuning it with a wideband/EGT/SAFC 2 and working out all the little bugs like stiffer engine/transmission mounts, hooking up the Cruise Control, getting the A/C to work again, aluminum radiator/electric fans, and new tires. Then maybe I'll look at a set of HKS 264 cams and gears since my ECU is already tuned for them. Other than that I don't plan on doing much else to this car as it is NOT my true project car
