New to the VG33. What the **** is wrong?
air_forced
Car: 2003 Nissan Frontier S/C 4x4
1989 Nissan 240sx
Just bought an 03 Frontier. VG33ER. Ran perfect for about a week. Then on a cold start it had a very rough idle. I let it warm up for a minute, but was gonna be late for work so i pulled out of the driveway. The car barely moved. Giving it gas up to 3000rpm it was still moving as slow or slower than if I had just let off the brake with out giving it gas. Would not go above 3000rpm and then the SES light started flashing. Pulled over, cut the engine and then fired back up. No problems. This has been intermittent, about once a week or so, for the last month. Pulled the codes and the knock sensor has tripped, and a multiple cylinder/ random cylinder misfire code. I can't figure out what's going on with it. Any ideas?
longtooth
Car: 89 d21 HB
Ignition module would be the first thing that comes to mind.
PEZi
replace the knock sensor... should fix it to be honest
there is a nice article in the stickies up top this forum that explains all stupidity of that part
longtooth
Car: 89 d21 HB
PEZi720 wrote:replace the knock sensor... should fix it to be honest
Yep your right. I remember reading that also.
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
What's the stored code?
air_forced
1989 Nissan 240sx
It's been awhile since I checked them. Was knock sensor and multiple/random cylinder misfire. Don't remember the codes.
I plan on replacing the knock sensor. Nissan is horrible with those.. Just seems like the problems it's been having can't all be caused by that sensor.
