It should look exactly like that pic (that's my car btw
), but anyhow... The engine is actually a pretty nice engine, running 165bhp and 160 ft lbs torque, it's right around the KA24DE.
In stock form it takes turbocharging fairly well, though it can be tricky with the 10:1 compression ratio.
As you've discovered, it uses a distributor instead of coil packs (turbo motors only came with those).
I've posted more info on the engine else where on this forum, just search for it.
