1fastbox06 wrote:Hey all, i'm about to pick up my brothers 1990 nissan 240sx coupe. It's a ka24e/automatic and i was hoping to turbo charge the lil' bugger. anyways, i was hoping on building a decent turbo setup for cheap.
The turbo i found is from a 84 chrysler new yorker 2.2l (garret TB0335). the specs are as follows
Garrett model number: TB0335 (T3 series turbo)
Compressor Trim: 50
Compressor housing A/R: .42
Turbine Trim: 69
Turbine housing A/R: .48
Horsepower Capabilities: ~275hp
Internal Wastegate: Yes
Wastegate setting: 7 psi
so my question is. with such a small housings and trim, and the wastegate setting at 7psi (which is what i'm looking for), how well will it perform as far as the powerband is concerned?
P.S. this will be a temporary setup, once i have the money for a manual swap and various parts, the whole temp setup will be going to my daily driver ( a k24a4 manual honda element.)
The turbo is slightly small in my opinion, but it should work decent for starts.
Powerband should be great low and mid, but is going to suffer high end.
