hawk86 »
https://forums.nicoclub.com/hawk86-u56532.html
Mon Mar 29, 2010 1:14 am
ok so fri I put some rad dye in the system so I could find the leak. So sat I pulled the spark plugs out to switch them out with some low temp ngk's and cylinder 4 and 5 had a crusted green dye on them so I take it its a head gasket. I was gonna buy another cometic gasket kit for it but ive been doing some reading and I guess the oem gasket kit is fine for me only running 12 psi. So I ordered the stock gasket kit. It will be done hopefully by next weekend.
Should I be putting anything else in the car while I do this? I got head gasket kit, timing belt kit, water pump, and misc seals. anything else?
