Thanks Wes...didnt really want lowering spring s on the Q just wanted to get rid of the dull black oems...same thing with the tension rods, i just figured since i was going to be replacing the struts with the "blues" i would do some other suspension upgrades.
Just wanted to add... These are the end links your refering to?Performance Polyurethane End Link Complete Sets-Made of HYPER-FLEX™ Performance Polyurethane.Complete end link set includes: firm durometer polyurethane bushings, zinc plated 3/8" grade-5 bolts, "nylock" nuts and heavy gauge washers. Use this chart only when our specific vehicle pages do not display applications for this item. TO FIT / SELECT THE PROPER SET-Vehicle must be on level ground or service lift (NOT jacked up, NOT wheels hanging and NOT having the suspension unloaded). Wheels should support the vehicle or lift jacks should support the suspension as if the wheels are supporting it.
Make sure stabilizer bar end eyelet (B) is parallel with the control arm (C). Many times they are not. You may be required to use a slightly longer or shorter sleeve length than the original. Measure sleeve length (A) and compare to the chart to find the correct set. (A)Length SetNumber 1" 9.8122 THIS IS IT RIGHT?1 5/8" 9.8120 2" 9.8123 2 3/8" 9.8125 2 5/8" 9.8117 2 7/8" 9.8118 3 3/8" 9.8119 3 9/16" 9.8124 4 1/4" 9.8149 4 1/2" 9.8121 I got the info from
http://www.energysuspension.com/pages/endl.html
Modified by jaeimwhy41 at 12:02 PM 6/2/2007
