This is not an auspicious start for an imported luxury V8 sedan owner who does not realize the requirements of restoring and maintaining such a car.tofudeliveryguy wrote: I just recently purchased a 1990 Q45 from an old man. Its got a hundred and twenty one thousand miles on it and a few bugs in it. .... and cash is tights right now
maxnix wrote:This is not an auspicious start for an imported luxury V8 sedan owner who does not realize the requirements of restoring and maintaining such a car.tofudeliveryguy wrote: I just recently purchased a 1990 Q45 from an old man. Its got a hundred and twenty one thousand miles on it and a few bugs in it. .... and cash is tights right now
Either you need to start reading a lot of the previous posts here, sell it ASAP, or drive it into the ground.
I am afraid for your car and recommend taking to a dealer for last rites.
PEZi wrote:Welcome! First off, leave the wiring you did... ditching stock wiring is never a bad idea. Just make it hidden so that its not ghetto!
Can't be sure on the tires... but I'm sure someone has the info, maybe in the Q subforum. Speedo.... can't be 100% sure because i'm not sure of the exact setup, but check the wiring and such for the speed sensor in the transmission if it has one ( I can only expect it does).
Enjoy your stay and hope you find all you need!
We've had many guys through here that said exactly that, and their cars lasted a few months before the components got too expensive to replace. To them, it was only a $xxxx car. They didn't understand there was no further discount on parts or labor because of its age. Good luck!tofudeliveryguy wrote:
Wow i asked for help not stuffy a** comment but thanks ive restored and maintained many cars so dont worry about me buddy ill fix it
well the car made a funny noise and since im a broke retard as you pointed out i just shot the car full of holes with my ak then my kid came down with the flu and since im not capable of being on your level of tuning i figured i wasnt fit to raise children either so i locked him in the truck and just burned the car to the ground. Thanks for your advice two birds one stonemaxnix wrote:We've had many guys through here that said exactly that, and their cars lasted a few months before the components got too expensive to replace. To them, it was only a $xxxx car. They didn't understand there was no further discount on parts or labor because of its age. Good luck!tofudeliveryguy wrote:
hey thanks for the help ill take a look at that sensor when the weather cools downQ451990 wrote:Alright, so let's get down to getting some things fixed. Your brake light problem is probably a bad sensor. It's mounted under the trim inside the trunk near the latch. It's usually a purple color... this sensor tells the dash to put the "Brake Lamp Out" or "Tail Light Out" warning in the odometer cluster if you have a bad bulb. When it goes you typically have what you described... a working CHMSL, and no voltage to the main lamps.
Check your sockets for corrosion and clean and replace them as necessary... install all new Sylvania LL or factory bulbs. I know this sounds weird but we have found that cheap bulbs draw more current than OEM, and apparently Nissan didn't design the brake lamp system for any additional current draw.
If you have a Pull-a-Part style yard (like http://www.pullapart.com) nearby that is by far your best source for cheap parts...
Heath
