I'd talk to an UpRev dealer to see what's possible and what's not. There's quite a lot that can be done.
http://www.uprev.com/dealers.php
Regardless of the 2-step, a properly tuned UpRev ROM will give you a little bit more power, and a lot more low-end torque which has helped me tremendously with my launches. Here's what we did, and some dyno graphs in result:
http://www.zcarblog.com/2012/04/13/perf ... wners.html.
It's a challenge to dyno a CVT, and most tuners won't even bother trying. If you're in Nor Cal, check out Z Car Garage in SJ. They tuned my CVT Altima and mrmurphz' CVT Maxima. The stock air/fuel ratios were completely illogical. The main benefits came from adjusting a/f ratios and cam timing. I've improved my highway fuel efficiency (using cruise control) from ~24mpg to ~30mpg. Serious gains.
I'm going to talk to Rob from ZCar about changing the valet mode, possibly increasing the rev limiter and making a super efficient map for long drives.
