New to the forum and I have a few ?'s.
armydog02
Car: 91 Integra
Hey everyone,
I am new to the site and I have questions about a red top sr20det swap into a 240sx. I am currently driving a 91 integra and I am getting ready to cross over to drifting.
1) Is the red top sr20det motor a direct swap into a 91 240sx hatchback?
2) Has anyone ran into any problems with the wiring harness? (i.e. If you connect everything up, do the stock gauges work?) I have no intention of using a jdm instrument gauges.
3) Does anyone make indiglo gauges for a 91 240sx?
4) Where do I find a tear down and rebuild manual for the sr20det?
5) Does the S15 headlight swap use the factory headlight harness?
6) Where can I find a step by step guide for the swap? I would like it to go as smooth as possible.
Any help on any of these would be great. Thanks in advance.
RMiller
Car: BBQing
1. Yes2. 89-90 (sohc) tachometer does not work, but 91+ does. Everything else works. 3. Probably, but most people on here don't care for things like that.4. Try searching in the SR forum.5. I've never done it, but I doubt it. Probably need to cut connect certain wires, just like in the SR swap.6. http://www.srswap.com works perfectly
I recommend you read the stickies, then browse through some threads.
