Yes, it is the hinge on the pass side(found out by going to everythinginfiniti.com, I navigate the site fine *shrug*), so I'll be placing an order tomorrow for them. If anyone has an idea as to where I can find engine diagrams for the car, I'd be most appreciative, I was going through some of the posts and I think that the little bit of idle vibration I have could be my pcv valve, so I'd like to know where it is in order to replace it. I guess I might as well put on here what I have been having problems with since I got the car. About 2 months ago, the car started to vibrate VIOLENTLY at idle, we're talking big block 5,000 carbed shake, that seemed to only happen at idle. about 2 weeks later, it went away, poof, gone, could barely tell the car was running at all. Now about a week ago, it started to vibrate again, but very faintly. A friend looked into it and said that the Q had a self-servicing feature for the spark plugs since they were before the 100,000 mile ones, that the engine would intentionally run richer to ignite at higher temps and clean the plugs out. I imagine that some, if not all, of the plugs need to be replaced, but as I was only able to get the pass side cover off, I am very scared, very very scared, to attempt the driver side seeing as you have to remove so much, I need to search the forum some more and see if anyone has written a good tut on it, maybe pics too
. I also need to replace the belts, I have a very loud noise at about 4500rpm on that goes away after upshifting and dropping revs, which definately leads me to believe its a belt, mostly from the sound. Thats not everything, but this post is getting very long, and well, I need to be at work in about 5 hours, so, I'm going to sleep! lol.
