New to the board, Have some tech questions. car vid included
CTDET
HEy everyone I was on here before but don't remember my login, long story short the car is finally running s13 sr20det, t3/t4 jwt ecu and 72lbs injectors and about ten million other things, should put down around 400rwhpish in theory...anywho, I'm having a few stalling problems, the car starts fine but during warm up in open loop it runs full lean, I have a wideband and its around 18, then it stalls out, let it sit for awhile and restart it runs fine if I keep the rpm at 3-4k then after driving it when I let up off the gas it will stall out (bov is recirculated) If I unplug the coolant temp sensor it starts fine and runs fine but the idle surges, I have cams but it's not that type of surge, I put a new temp sensor in and it has the same problem I'm wondering if it's a software issue with the jwt ecu...any thoughts? any help would be appreciated
current fuel set up = jwt ecu 72lbs injectors, cobra maf intank fuel pump, new coolant temp sensor and new nissan oxygen sensor
Here is a vid of the car at 15psihttp://vids.myspace.com/index....19462
