Daunttless »
https://forums.nicoclub.com/daunttless-u116.html
Tue Sep 10, 2002 8:42 pm
Well, doing all that to your engine will easily cost several thousand dollars. I will be selling prebuilt ones for 3000, you can find themm on my website but at this point all there is is tentative information. If you build the car for N/A power you won't want to/be able to turbo it as your compression ratio will be too high. If you lower the compression ratio, you'll have no power. If you want to spend like 3,000 dollars building the KA24DE, just to put in an SR20 8 months later, you pretty much might as well spend the 3,000 dollars putting in a SR20 right now...
Also, as far as the car and engine deal goes, if you can find a 240 you should buy it, they aren't THAT easy to come across, not like a honda. It would be easier to buy the 240 first, rather than build an engine and search for it, because it might be months before you find a suitable one. Then you'll just have that engine sitting there all that time. : )
So if you want to go Turbo, either KA-T or SR20 theres no point in building the engine as of now, not if you plan to do it 8 months later either way. Enjoy your day.
Any other more specific questions we can answer for you?
