irregular.s13 »
https://forums.nicoclub.com/irregular-s13-u231323.html
Thu Feb 06, 2014 1:04 pm
well I have 2 motors. One I rebuilt completely, only original part was the bottom block and crank. I had the same result, low compression in all. cyl 1 & 2 had the highest compression at about 115 and 120, but still lower than the recommended, cyl 3 & 4 was the lowest at 65 and 65. I started with the re-built motor, and i thought maybe the valves need to be reseated, so I took that motor out and used the original motor that came with the car (which ran perfectly). All i did with that motor was replaced the timing components (chain, guides and tensioner) and took switched the cam to the r4 cam. And still, I'm getting around the same figures.
