I don't know where the stock injectors run out using a T28... I just know the T25 won't max out the injectors at 14psi, and that's pretty much the end of where the T25 makes power... Most people on here have S13 SRs, and the ones that upgrade to a T28, usually follow that up with some 550s, a Z32 MAF, and a tune, so you don't hear of too many people really testing out their injectors against a T28..
In my opinion, power building should be done in the following order...
Fuel Pump
Injectors
Turbo
Cams
Your fuel supply should ALWAYS be first on your mind... This winter I'm already planning on 1000ccs for my setup because I'm pretty sure my 810s will run out before my GT3071 will..
