jemil118 »
https://forums.nicoclub.com/jemil118-u1859.html
Sat Oct 05, 2002 8:22 am
Okay, I might be crazy here, but isn't a too big exhaust system a bad thing, like a 3 in. exhaust on a non-turbo engine? The way it was explained to me was like this. Exhaust comes out in small bursts, pulses if you will. Different types of engines give out different sizes of pulses..ex. V-8 and tt V-6 will give out a large pulse, V-6 and turbo four will give out med. pulse, NA 4 cyl gives out a small pulse. Now you don't want the diameter of the exhaust to be bigger than the diameter of the pulse. Why is that bad? Because the pulses tend to bounce back and forth inside the exhaust system, not exiting it quickly. Now in high reving engines, commomly found in imports, the cam lobes are positioned so that the exhaust valves can be open at the same time the intake valves are(called valve overlap). Now under normal situations the pulses cause a vacuum that sucks the exhaust out of the combustion chamber. But when someone puts an excessively large exhaust system (or a dual exhaust on an inline 4), and the the pulses start to bounce back and forth that vacuum is greatly reduced or even absent. When that happens, and the valve overlap occurs(remember at high rpms), the exhaust pulses can back up and can actually be pulled back in to the combustion chamber, and be burned again, causing a loss of power, and damage to the engine....Sorry if that was kinda long, but am I wrong on that?
