AZhitman wrote:Welcome aboard!
Definitely some weird activity going no there - Sure you didn't get a "Katrina car"?
You said the "fog lights didn't work when you bought them" - You mean when you bought the car?
You haven't done any electrical work on the car, right? No stereo stuff?
The other stuff almost sounds like a Body Control Module - I'm not sure where it's located on a Sentra, but that affects a lot of the systems you mentioned.
Go through EVERY fuse in the fuse panel, making sure they're all intact and functional.
I'm leaning towards the BCM as the culprit here...
I bought the car from an Acura dealership and was assured it had a clear title and thats what I got in the mail. I haven't personally done any electrical work but it does have an aftermarket radio (AIWA).
The fog lights haven't worked since I purchased the car until randomly one day without the car on (almost ran my battry down and needed a jump). Then I pulled out the fuse and they turned off. Never had the problem again. (They still don't turn on tho)
I've checked both fuse boxes (under hood and dash) but couldn't find any fuses that were blown.
Oh. And I forgot to mention my cruise control doesn't work either. It turns on but it doesn't set a speed.
