SuperSpeed »
https://forums.nicoclub.com/superspeed-u19529.html
Mon Feb 06, 2006 11:35 pm
I dont know about the manifold itself, If your lookin for performance, you should port and polish your stock manifold. If your lookin for a bolt on Intake sys, I recomend Injen's Cold air intake. As far as the clutch, it may just need some new fluid, and a good bleeding, could also be an adjustment on the cluch master cyl. The adjustment is under the dash board, just behind the top of the clutch pedal, caution with the adj, use small turns, and test it , then repeat the process until it works. Good luck, and welcome.
Nissan Shift_ Into perfection.
