New to Nissan and have questions :)
A forum for the Nissan Quest... minivan lovers unite!
Shpreetzer
Hey guys new to Nissan bought an 04 quest ,125k mikes. Upon driving home after purchase realized that tcs abs and o/d button do not work but there is no indication of a fault, like no lights on dash saying theres a problem. Van works great except for those issues. Just wondering if any of that was common or if it's something simple I should look for. Also noticed in the maintenance button that one tire says ** and scrolls flat tire, obviously the sensor but does that have any effect on the other systems?
Thanks
Michael
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
Not sure that the TCS and ABS would be affected by the TPMS. The O/D button definitely wouldn't though. Usually that is just a button that tells the TCU to keep the car from shifting into O/D. I wonder if the TCU is on its way out? Those are all systems that require input from that.
Can you get your hands on a code reader? Not all problems are going to pop a CEL. Less than half will, actually.
Shpreetzer
I checked the codes and nothing came up at all. I do think that the abs light might be on but not centered well in the dash cause I do have a bit of yellow light making its way around that area.
Return to “Quest Forum”
