new to nico, starting sr swap
knoxvillenismo
Car: '90 Nissan 240SX hatch. (sold)
'95 240SX S14 5speed. (sold)
back in the '90 hatch. ;)
srraptor wrote: And I think Knoxvillenismo called the coilovers, not sure though, he already yanked my hks fmic and hks hi power lol
ya rob wanted the tanabe's and old z32 brakes. lol. i love that new exhaust. i need to pressure test that fmic tho. i have a feeling it will leak...
motoman399
Car: 98' wrecked (RHD coming soon) 240
BALLS!!
srraptor
Car: 1995 Nissan 240sx
1996 nissan 240sx sr swap coming soon
1998 nissan altima gle
*totaled* 1989 nissan 240sx
im pretty sure there busted anyways, got to wake up my wiring man and get this done!
knoxvillenismo
haha...donny the wiring man.
srraptor
Okay seriously sick of wiring problems. Anyone done this before that could help me out? No fire, bypassed the fuel pump relay so it's getting fuel...
motoman399
are you getting injector signal?
srraptor
nope, i can make it hit with ether though, no power to injectors or ignitor
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
Contact OM3GA through pm.
srraptor
i have the feul pump working! and fuel injectors are getting power! but no start... crank angle sensor wiring off?? any suggestions?
srraptor
Bump? Lol still can't figure it out... Fuel pump isn't coming on now, turns over but doesn't even try to start, I'm about to just go rhd and replace all the dash wiring lol
knoxvillenismo
BUMP cause i want this s*** running. lol
motoman399
ok so what exactly doesnt work? from what i understand its the fuel pump not turning on. what about the spark and injectors.
i will try to help you figure it out, but just beware that i dont know d!ck about doing SR swaps. but ill help the best i can. so lets get rollin on it.
what exactly did you do to the wiring harness? did you modify it yourself or did you buy a pre made one? also did you do anything else at the same time as the swap? did you put in a new fuel pump too? are you getting power to the pump?
PyR0NiAk
Holy s***... moto is trying to help with an SR. I'm pretty sure the Devil is hating his current blizzard.
motoman399
^^ lol well he is also going to hook me up with his left over KA parts. so i figured i would do what i can lol.
on a side note, dont you know a lot about sr's?
PyR0NiAk
To be honest, I haven't taken the time to read through the thread yet. Been busy deciding what route I'm going to take for my bottom end. 85% compression loss on cylinder #3. Give me a couple minutes and I'll see if I can take a stab at any of it.
motoman399
wow should have stuck with a ka lol jk jk im sure between me and you we can figure out the problem.
PyR0NiAk
I have no idea why your wiper motor wiring is failed... That wiring shouldn't have been touched. At least it isn't in the S13. I say pull your harnesses and order both upper and lower from Wiring Specialties. Also, that relay is kind of an odd relay. I'll bet money that relay lost it's ground, so try grounding it and stop bypassing it. By passing relays and things is not the route you want to take with this. You're just causing yourself more issues with diagnosing it. Also, if you popped the big 75W fuse, your pump won't come on. That fuse tends to blow when a battery wire is crossed, or if your alternator is grounding itself out. (Something touching it, or the inside of it's jacked up.)
PyR0NiAk
motoman399 wrote:wow should have stuck with a ka lol jk jk im sure between me and you we can figure out the problem.
I had intentions of building the bottom end anyway, but I wanted to get the motor running properly and get my chassis swap done first. :(
srraptor
I'm not getting juice to the injectors, crank angle sensor, or fuel pump, if we bridge some wires on the dash plug the fuel pump will come on, but it stays on, the problem we've got is that we cannot find a wiring diagram for my car or the sr that is correct. We found tons that are somewhat close, but nothing that's right, fsms don't have the same wires listed in the same location and the wire colors are all wrong lol, so I'm stuck. We haven't cut the sr harness except to extent the maf and o2 sensor wiring, ka harness is cut at the dash plug, we were making an adapter to keep from having to mess with the actual harnesses. Any help would earn you free beer lol or BBQ lol
PyR0NiAk
Why not keep your beer and bbq money and use that toward a wiring specialties plug and play upper harness.... Your stock SR bottom harness will be fine...
srraptor
Did they finally develop one for s14 sr into s14 finally??!! Cause my ka harness is delooimed and cut...
motoman399
the 95 s14 ka FSM didnt have the right wiring colors and pinout? it has always worked for me. are you sure your not looking at it backwards. its pretty easy to look at it wrong
srraptor
Ya, it's not exact for the 96 auto se, and all the wiring diagrams I find for the sr are a little off, I'm probably looking over something small but me and my friends can't find a diagram that's close enough. We've pieced together out own I'll post on here when I get home you can look at.
Morph
Car: 91 Sr Powered Coupe
Dude you could spend months trying to track down that bug. Contact OMEGA and see what he can work out for ya. When i found out about the plug an play harness i got a quote for an s13 to s13. Email him and see what he says for a S14 to S14.It will cost you more if he hasnt released it yet but dude the loss of time and fustration is well worth it in my opinion.
srraptor
Eh if I can't figure it out tomorow I'm taking it to over the top motorsports, he quoted me $120 for wiring it, re-looming it and all, and hoping nothing else is wrong with it.
knoxvillenismo
srraptor wrote:Eh if I can't figure it out tomorow I'm taking it to over the top motorsports, he quoted me $120 for wiring it, re-looming it and all, and hoping nothing else is wrong with it.
orrrr steve could do it! certified nissan master tech for 9 years. lol. got robs rb running so there is obviously nothing he cant do. :dblthumb:
srraptor
Ya, but ott is gonna be faster and he's re looming it
motoman399
wasnt this supposed to be a weekend thing lol
hopefully you get it going soon. im kinda lost. sorry man.
srraptor
Well if I could find everything for the wiring it would have been a weekend thing. The engine was in the car in one weekend lol. I'm definetly making a wiring guide for s14sr>s14 on here when I'm done. It's kinda weird that I find more info on Lexus v8 swap wiring than mine lol
srraptor
Update ftw!? Tried a wiring diagram I thought would work, had my friend help me label the wire before I pulled them out. Wrote the wired colors with corresponding pin on a peice of paper and started depinning. My friend left and I started repinning when I found out that he's partially color blind... So my wiring is screwed even more lol. I'm pretty sure I can get the wires back where they go, but I'm gonna need a different diagram lol. Anyone have a link to one that might work? :ohno:
