New to nico r32 from montreal
A forum for owners and fans of the legendary Nissan Skyline and Nissan GTR.
frankydodo
Car: r32skyline
Hey guys!
My name is Francis , i'm 20 from montreal quebec. I own a 1990 r32 skyline, its my second one.
Its a gtst with a rb20. When i got it it was stock except a fmic and intake,
Last summer i added
Kinugawa hybrid rb25 turbo (great turbo)
front facing intake
blitz ss blow off valve
3'' hks exhaust
wideband/boost gauge
Hdi EBC-R (great for the price!)
catless
Turbine size compare to stock
Look at the size of the compressor housing
I still have to install
440cc deatschwerks injector
z32 afm
Tomei poncam
raw brokerage underdrive pulley
e-fan for the rad
delete the a/c
Right now it looks like this
And to release all the potential of the engine i bought a rb20 socketed ecu yesterday for reallly cheap! It got a chip for a rb20 afm with 1000cc injector, not really what i need! Does CarlH still do eprom tune? If yes it would be awesome to encourage someone of the forum!
I'm aiming for atleast 320whp @18-20 psi.
Thanks guys!
Frank
sx moneypit
Car: 2010 Nissan 370Z
1986 Toyota MR2
Welcome to NICO!
frankydodo
Car: r32skyline
Thanks mate!
themadscientist
I dig the gold painted T rims. Never seen that done and it looks pretty sharp!
frankydodo
Car: r32skyline
When i got the skyline it has a set of ugly green wheel. The set i have are gtr wheel. Forged, lighter and wider than gtst wheel. I didin't installed them when i got them i wanted them gold . Some here's the result!
frankydodo
Car: r32skyline
more pic of my little build
Battery in the trunk
Bunch of parts i installed last summer
Then the turbo swap
It was a hell of fitting cause it was not clocked like oem and oil line did not fit 100%
But i managed to installed it and love that turbo!
Then the ffp, man this was the most frustrating part i ever installed! With motor in it was a pita to bolt the 11 manifold bolt!
first test fit
Didn't like the ''chromish'' effect so:
Also i needed a bov because the oem is on the j-pipe!
Cannot leave the valve cover all dusty and dirty
Almost finish!
Right now it sits like that
But i wont be like that for long because i bought this, also need to redo the occ line more stealth (black) , a little engine bay degrease also .
Hybrid performance manifold, Alot of good feedback from guys at skylines australia forum. Talked alot with the owner and bought one but damn the shipping is so long from new zeland!
And all that:
Can't wait to get my car in april since its stored for winter (quebec yay!) Hope to get it to 300-350whp
Frank!
themadscientist
I see you have a bit of style. Digging the contrasting colors and somewhat cosistent theme. Quite refreshing I must say.
frankydodo
Car: r32skyline
Really like the Black/gold contrast as you can see ! :P
frankydodo
Car: r32skyline
Was looking for a new snail that could fit the topmount manifold better then the rb turbo and i think ill get this one
Kinugawa td05h 18g . Turbine and compressor size are +/- 2mm like a garret gt2871r.
themadscientist
Were it me I would go for a 3071R
http://www.atpturbo.com/mm5/merchant.mv ... RT-TBO-020
or 3076R
http://www.atpturbo.com/mm5/merchant.mv ... y_Code=GRT
I'm not down with Taiwan turbos.
usafdarkhorse
Car: 1990 Honda NSX #382
1989 Nissan Skyline GT-R #2317
1972 Datsun 240Z
Welcome to the forum
frankydodo
Car: r32skyline
I saw a couple rb20 with gt30xx and i think its way too laggy, maybe that with the cam it will compensate a little spool time, then maybe i can get the td05h 20g. The comp wheel is a tad bigger .
themadscientist
You need a little bit of cam to spin it, yes. A mild set of 264s should make it sing and idle smooth.
frankydodo
Car: r32skyline
I already have tomei poncam waiting in my basement ! Cant wait to install them! But i see very good responsive result with the td05h 18g . No lag and easy 320whp = enough for me :P
HHan
Very cool R32 Frank. The paint and mask work looks solid too. What gold is that and are you spraying it via spraygun/airbrush or straight of a can?
frankydodo
Car: r32skyline
Thanks hhan
Spray can but hell of a prep job. Sanding sanding priming sanding.....4 coat of gold. 3 coat of clear . Than a water sanding and here is the result!
Return to “GTR Forum / Skyline Forum”
