New to nico club
Yhrs13
Car: S13 240sx in the works
Hey my names yamil I am 16 and have a 90 240sx, this is my second one and I was wondering if tigerjapanese.com is a safe website to get a swap from, planning on going rb25 mainly cause I already have the mounts and driveshaft, thanks in advance
Dittoz7
Car: 1997 2f0WtY SE!
Welcome, here you go you might wanna read this.
the-240sx-info-introduction-faq-thread- ... 83490.html
Yhrs13
Thanks and I know my history of the 240sx quite good
300ZXttZMAN
Hello welcome to nico club.. Not real familar with the luck of the rb motors purchased through a jdm engine depot. But here check this out. It is from the 300zx (Z32) section.
jdm-engine-experiences-noobs-read-t530009.html
^Z32 ppl that swap their na for a tt have had major problems with the jdm motor's.. Even the ppl that are just replacing a TT motor (the z32 guys recommend to rebuild..)
So maybe you should look into buying a used RB motor that knowingly has something wrong with it and just rebuild it...
Yhrs13
Yea when I get the motor I'ma do the timing belt, the water and oil pump,and a full oem gasket kit, but compression test first lol, that's why I'm asking cause I'm already expecting the rebuild, it's never a good idea to just throw in an engine just like that, especially a Jdm engine
300ZXttZMAN
^ Just making sure you knew
Yhrs13
Yea, I'ma most likely buy it off my friends that has bad piston rings and take it from there since most of the other things are in good conditions
Yhrs13
Btw your build looks sick as f*** !!
