AZhitman »
https://forums.nicoclub.com/azhitman-u113.html
Wed Sep 13, 2023 5:37 pm
I've rehabbed several "sitting for years" cars, most recently a 90 Z32 with 50k miles.
You're probably not going to like this, but exactly what VStar said is accurate. Plan on tires, now. They're flat-spotted, from sitting, and you're not fixing it by driving (the steel belts take a shape and stay there).
Timing belt is due (based on age, not miles). With that, you're gonna do water pump, front seals, all coolant hoses, serpentine belt and idler, and everything cooling related.
Fuel hoses should all be replaced. The clamps were loose because the rubber is dissipating away. Fuel filter should be done as well.
Anything rubber (suspension bushings) should be on your list. Brake fluid and trans fluid should be flushed, and diff should be serviced - but don't be surprised if you see some oil or trans leaks in the next few weeks. Without normal use, those seals shrink and fail.
Invariably, someone will read this and say, "No way, it's got low miles." And they'd be wrong. And then, one thing after another fails (just as water finds its level, failures move on to the next-weakest part of the system).
