New-to-me 720 Lot's of Questions!
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
Demihuman
Car: 83 720
Hi everyone, I just got a 720 and while it old and fifth gear doesn't work I realy like it so far!
I found a used transmission with waranty from a shop for $350 does that sound reasonable?
It is very hard to get into fifth and it pops put of fifth with any deceleration. I also hear a little grinding when I put it in reverse but it sounds like it may be comming out of the rear-end does anyone know what that is?
I am probably going to replace the clutch when I do the transmission. Looks like there is an exedy stage 1 for around $150 or just an OEM for a $100 any thoughts?
I also need new seats REALLY bad! Does anyone know what fits in the 720?
OK, fun questions: How much HP can I expect from a cat back exhuast? how about a weber carb? any other real obvious performance mods?
It seems like the Nissan/Datsun old truck forums are in flux so if anyone can point me toward the info I would appreciate that too!
Thanks
phlebmaster
Car: 1973 240z L26 4spd rip roar and ready to go!
WELCOME TO THE FORUM!
My advice is to look into junk yard prices before you pay $350.00 for a used transmission. The warranty is only as good as the paper it is on, and they are just taking a chance that the used transmission doesn't break before the warranty is up. Your odds may be better going with the JY route if you have a way to install it yourself.
Go with a new clutch...stockers are just fine unless you plan on drag racing or pulling.
Anyway, we like pics here so post some up of your ride.
IMH
You could replace the baulk rings, seals, etc. in the trans you have. In other words, do a minor rebuild. It would cost less than the trans from the shop and you'd know what you have when compared to a junkyard transmission. When I buy a trans from the junkyard, I always do a minor rebuild on it before I install it. I really don't like the possibility of doing a job twice.
Demihuman
Car: 83 720
Hey IMH, Do you think if fifth gear is really chewed up a rebuild will help? I mean wouldn't I need to replace the actual gears? How hard is it to do?
I have never cracked open a transmission but I am not totally adverse to the idea. It sounds like a refresh of the new transmission is a good idea anyways.
So it looks like there are some 50% sales at pick and pull this week. So that could be like $50-100 for a transmission. I will see what I can find.
Also I will get some pictures up soon!
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
You could get a new exedy oem replacment clutch. Mine for the 240 was like $103.
Don't forget to put some money down first to do a tune-up and replace all fluids.
Demihuman
Car: 83 720
So I got a new transmission of the correct length at pick n' pull for $120. it was in an 83 4x4 king cab just like mine with 160k on the odo. I also scored a factory service manual for like $8 on amazon. Did a bunch of research on transmission anatomy and how they are supposed to work. I pulled the transmission apart today and it looks pretty good.
The baulk ring on 2nd is pretty worn, about .05 mm smaller then the shop manual says is good. the end play on the gears is about .005 to big on all but third and reverse looks pretty chewed up.
You can see the reverse counter-counter gear hear. I think the right side of the teeth should look like nice sharp wedges but instead they look more like bullets [IMG]<table style="width:auto;"><tr><td></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From 83 720 trans</td></tr></table>[/IMG]
Here is the notorious fifth gear. To me it doesn't look too bad what do you guys think? [IMG]<table style="width:auto;"><tr><td></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From 83 720 trans</td></tr></table>/IMG]
Here is the ride:
four wheeling over some gnarly cardboard ;-)
I think after we get the trans all worked out and the engine in a nice tune I am going to get some nice black steel "crawler" style rims and some knobby tires!
breadbox
89 Koop
84 720 4x4KC
First thing I did after I got my 720 was replace the fluids.
Demihuman
Car: 83 720
Yes fluids are very important. Right now I am working on the transmission. When I put it in the truck I will definitely use new fluid. I have a big box of redline all ready just for that. I will also change the fluid in the diffs and the transfer case. The oil and coolant are fresh already.
breadbox
89 Koop
84 720 4x4KC
And get an oil pump to fill your trans. I didn't use one and ended up filling it with some fish tank hose with a funnel in it thru the shifter hole. It took like an hour and a half for it to fill by gravity and it spilled a bit on my passenger monster mat and the truck smelled like trans fluid for a while.
PEZi
yeah the trans is annoying
i used a cut up garden hose... one end in the trans the other up through the engine bay.... it worked ok
IMH
That's gear lube not 'trans fluid'. Use a pump. It's a lot faster and not nearly as messy. Fill it through the hole in the side of the trans. That's whait it's for. If you fill it through the shifter hole, you'll over fill it.
PEZi
not sure if i made it apparent or not that i did you the hole on the side of the trans.... i didn't even realize bread was talking about filling it from the top.... i didn't realize that was even possible
IMH
PEZi303 wrote:not sure if i made it apparent or not that i did you the hole on the side of the trans.... i didn't even realize bread was talking about filling it from the top.... i didn't realize that was even possible
I was more or less responding to both. I have a fluid pump but even a hand pump like the ones they sell for the 1 gallon and larger containers of gear lube make the job much easier than a 'gravity' fill.
PEZi
yeah i can imagine... i need to get one for next time
zedman280
Car: 78 datsun 280z (turbo) / 1990 nissan 300zx twin turbo / 1982 datsun 720 4x4
As for your SEATS question.
Pretty easy to fit just about anything in there. However, I threw a pair of high back buckets out of my old 83 280zx. Took the sliders off the stock seats and threw them onto the 280zx buckets, and I believe I only had to drill holes in teh rear of the seat to mount the sliders up and everything else bolted up perfectly. Too easy, they are way more comfortable and look better !!
Return to “Datsun 720”
