A little about the truck, its an '83 4x4 king cab with the 2.4 liter 8 spark plug engine pretty much stock except for 33" tires. So far all I have done to it is replace spark plug wires after taking it off road and nearly stalling out in a mud hole. The wires were done for, one of the coil wires had arced almost totally. Today I received a new rad cap, distributor cap, spark plugs, coolant hoses, oil filter and oil, air filter and wiper blades from Rockauto.com. After reading some posts on here, I will order a new fuel filter as well. I started working on vac lines as some are old and rotted, and I'm not convinced they are all routed properly. After replacing the plug wires last week, I took it out off road for a day through mud holes, up hills and down desert roads. It did great, didn't give me a hint of trouble. I totally fell in love with this thing, I find myself leaving work in a hurry just to go for a drive in it. The last couple of days, though, it started acting up. I'm not asking for help at this point, as I still have to change all the parts I ordered which are really just PM anyway. That might fix the issue. But anyway, it starts cold just fine even though the choke seems to be open all the time but it seems like after I drive it for about 15 mins or so, it loses power and start to buck and I basically have to idle home. I'm kind of curious if anyone else has this problem.
I will say however, I came into this truck knowing it would be a project and as such, I would love to hear any suggestions or tips that might save me a headache. I have been told to get a weber carb, but I would be just fine with the stock one as long as I can get it running correctly and reliably. I just don't really have the money to spend on that "just because". Hopefully tomorrow I can finish work early and spend some time installing all the new parts I got, as well as pick up a fuel filter on the way home.
