If you are putting in your own headunit and you've already cut the factory harness to pieces then just run your own wires.boogiesj30 wrote:Let me tell you now...
In my pursuit of installing my Dual reciver, I kind-of cut all the wires from the stock wiring harness of the Bose system. I should have came on here first, but I wasn't thinking straight. Just wanted to let everyone who replies know that converters are out of the question. Unless I can get a stock harness and put it in if it is possible....
HELP!!!
For how much and how will install it?misfit6794 wrote:You need to replace the speakers as well. The bose speakers will not work with an aftermarket headunit. I've got a stock harness you can buy if you decide to change your mind.
Sounds like you might be better off taking your car to an audio shop.boogiesj30 wrote:
not true...i have a JVC headunit running all 4 BOSE speakers...i dont know how he did it but it works and sounds great!since i changed the head unit the sound has had more depth to it if that makes any sense at allmisfit6794 wrote:You need to replace the speakers as well. The bose speakers will not work with an aftermarket headunit. I've got a stock harness you can buy if you decide to change your mind.
If you don't have the adapter, you can use the stock speakers but you have to modify them to bypass the built-in amps. My 94's stereo was like this when I got it. I have since ran all new wires and don't use any of the factory wire harness. I even pulled all the seats and carpet out to run them. Got to pressure wash the carpet while it was out.kbflip02 wrote:
I like Crutchfield's service but you pay for it. Getting $40 worth of adapters for free only means that you paid at least $40 too much for the stereo.brandonjustice93J30 wrote:all of mine work with an aftermarket unit....nissan/bose converter came from Crutchfield when I ordered my unit, was part of a free install kit for buying the radio. Normally $39.99
You mean like this one for only $99?brandonjustice93J30 wrote:actually I got more than that free and I only paid $149 for a Kenwood KDC MP2035
And you didn't pay any shipping?brandonjustice93J30 wrote:actually I got more than that free and I only paid $149 for a Kenwood KDC MP2035
So where is the stock amp located at? I'm trying to do everything myself. Engine work, body work, electrical, w/e... I appreciate those who stopped by and left some notes in the thread for me.gr8scott72 wrote:
