float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Wed Oct 22, 2014 4:30 am
This HAS to be a ground issue. It's too coincidental. After I bought my S14, I drove it home and it ran fine, but the valve cover leaked. Pulled the cover, replaced the gasket, but in the process, removed the grounds on the exhaust side. I put them back on, but after that, EVERYTHING was haywire. Ran poorly, knock sensor code, crank sensor code, etc. I knew the ONLY electrical thing I messed with was that ground. I took it back off and looked at it, and it seemed fine, but I used some sandpaper and lightly sanded both sides of the ground wire eyelet, used a wire brush wheel on the bolt, and sanded the head where the eyelet bolted down. Then I used some conductive anti seize (like what you would use on spark plug threads) and put it on all of the surfaces, then put it all back together. Fired right up, and ran perfectly. It didn't look corroded, but it was. Afterwards, I think the issue was that the aluminum was corroded and wouldn't make contact. Corroded aluminum doesn't look that different than uncorroded aluminum. I would also look in the FSM and find out what that ground is for. If it goes all the way back to the ECU, use a multimeter and confirm that it has no resistance to ground AT THE ECU plug. You need to unplug it from the ECU to properly test it. If it doesn't go back to the ECU find out what it goes do, and confirm that it has no resistance to ground. Also, confirm that all of the metal parks of the engine (both heads and the block) all have no resistance to ground. Also make sure the negative battery cable has no resistance to ground.
