Intakes are intakes. The real difference is in the filter that you use so spend the extra money and get a good one. As far as the pop charger goes I had one on my Z and I was happy with it. Theres been a lot of talk over the years about sway bar upgrades on a SER and if I remember correctly the part numbers for Nismo and SERs are different but the diameters are the same. Personally I never plan to change mine. If you want to tighten them up a bit you can look into the adjustable Racingline endlinks.berretta28426 wrote:Great car! I just got mine last month....exact same car except for the red inserts, I have grey. I'm thinking of getting the pop charger from JWT, does anyone have thoughts on these? Also what do people think about a sway bar upgrade? I heard the SE-R already has the Nismo Sway bar, is this true?
DrewH wrote:No problem. Are you lowered berretta? Regardless if you are or aren't probably one of the easiest to install, reasonably priced, and effective handling mods (since you own an SER) is a strut tower bar. Heres a link..
http://racinglineperformance.com/shop/p ... ategory=18
If you aren't lowered thats one of the first things I would do. That would improve handling and get rid of that god awful factory wheel gap in the front. Somebody on another forum once said "I swear a baby dies every time I see that wheel gap." The Racingline springs are pretty drastic up front but if you search you'll find plenty of pictures of other setups.
Sorry for the hijack OP but your car's looking good. I would advise against getting your forged wheels powdercoated since the heating process can overage the metal and actually weaken it. I wanted to get mine powdercoated black but after researching it looks like paint and clear coat is the safe way to go.
