Yeah If you get the retune (I cant rem if you "need" this with a s-afc but I do know you dont "need" a s-afc with a retune it just helps especially with a atmospheric bov) and s-afc you dont need the FMU.
The fmu is there to put extra pressure into the injectors making them flow more then normal at 100% duty cycle. With the stock ecu and mass air flow sensor, it will sense a ton of incomming air and be like wtf is this. Then it will max out the injectors, but it wont be enough as at stock psi will only be 260cc. The FMU is there to increase pressure as the boost kicks in, per psi. This takes up the slack for when the normal ecu bugs out and dumps 100%, but now it will be 100% plus extra pressure simulating a larger injector
Thus no boom boom, to an extent of course hehe
With an FMU you WILL need a new pump, a walbro 225 pump will be the best option in my humble opinion and many many others. Its relatively cheap drops right in basically and has a proven track record in KA-T and SR setups. The stock pump just cant flow the needed pressure. And since you WILL need a FMU you WILL need a new pump
See how it works hehe. If you fail to follow these steps you WILL need a new block hehe
Any way some FA setups can be found HERE of peoples times with just an FMU of some sorts. Its a good thread because it shows a quick example of different setups, and how they vary, on the low buck approch.
Heres another I recently read, again FA (dont know if there is a cross forum ruling here but oh well), concerning s-afc injectors and FMU's and simple setups that can be found HERE
Im sure some helpfull info can be found here just gotta try searching for different keywords.
