New to forum, a few questions~~
mark241307
Car: 2005 Nissan Frontier 6-speed manual, 4.0L, 135,000m
2000 Nissan Frontier 5-speed manual 3.3L 219,000m
Hello everyone, Im a new poster but have been using this forum for my 2000 Frontier 5-speed 3.3L. I have a few questions to ask about maintainance for this truck. I never got an owners manual when i bought it. I was wonder how much oil 2 add when I change the oil. I can't seem to find anything written about it under the hood. I've been putting in about 5.5qts. and it seems to run fine. Just wondering if there is a set amount I should be adding? Also, I have never done the shocks and it has been a bumpy ride lately. Mainly in the rear. I was wonder what steps I should take to help it ride like it use to. I dont have much experiance with shocks or springs. Can anyone tell me what this truck uses as far as shocks/struts/springs? Is there a u/v joint I could replace as well? My frontier is a 4-door. I would like to lift it up a little in the process as well. Maybe 2-3inches. If anyone can explain a little about this process for me, that would be great. I also welcome any web-links about these topics. Thanks in advance~~
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
First off, you're putting way too much oil in the engine. With a new filter, the 3.3 only takes 3.5 quarts of oil.
As for shocks, that's an easy bolt on replacement. If you're going with a 3" suspension lift, there's plenty of writeups on the web on how to install one. As you get closer, I can point you to links I've written on installing a suspension lift on a Frontier. There are also several companies that sell them. Consider this before buying new shocks - the rear shocks will need to be longer.
I like Ranchos for reasonably priced decent shocks. Rancho 5188s will fit your front stock or lifted. Lifted, 5116's will fit the back.
If you do a suspension lift, look at upgrading steering components as well, as the stock stuff will become problematic over time with a lift.
