scarycanary wrote:Just you said, we took care of the water pump and valve cover gasket ourselves. Cost me around $50 compared to the $500 I imagine it woud've run me. As far as the muffler, I put on some of that terrible quick fix autozone muffler tape with a clamp. To my surprise it worked out quite nicely. "Good" tone.
For now I suppose I will hold off on the bushings. Is the strange body shift on turns higher than 35mph a tie rod issue? It's as if i pulled the e-brake on the rear end bad.
tie rods are in the front of the car.... (though i just realized i mistakenly called them control arms in the simple question thread....)
You could also just have bad stock shocks (or, have bad shocks as well). At high speed, especially if you also have some bad bushings, they can make the rear end of the car do terrifying rocking/bucking things. To check, push down on the back, and if it goes down easily, and when you let it up, sort of "bounches" a little, or just generally comes quickly, then you probably have bad shocks. They make every otheng suspension problem much worse.
My (probably bad) suggestion is that you go buy a socket set, torque wrench, jack and stands, and do whatever you need to yourself if you have the time. More fun and a lot cheaper, as far as generic things go. One of the stickies in this forum has a link to the factory service manual for your car, tells you procedures, torques, specs, as nissan intended them.
