tree fingers wrote:I have so often read people say things like MAF sensors have a static horse power limit, but I can't wrap my head around that.
They do, but it's not like every Nissan engine got it's own MAF for its own specific horsepower rating. There a a couple of ranges, and there's usually some room to grow. (airflow wise in the MAF)
tree fingers wrote:The volume of air that an S13 T25 pushes at 14 PSI will surely be different than the volume of air pushed by a S15 T28 at 14 PSI?
Yes, and you have to tune your ECU to suit the changes. A more efficient (newer) compressor usually puts out a slightly cooler, slightly denser charge, while still drawing in the same amount of outside air, as seen by the MAF before the turbo. So you'de have to add fuel to keep from leaning out, and of course to make good use of the extra air in the cylinders.
tree fingers wrote:My general concern is.. after my engine is broken in, will the stock MAF be sufficient to run the S15 turbo at 14PSI?
You'll have to see, but probably yes, or very close to it. If you get unexplained fuel cut in high boost+RPM, then you've reached the end of your MAF. If you/your tuner is tuning via an emulator, you can maptrace your VQ table. If it reaches the last cell, your MAF is (almost) maxed out.
mdb4879 wrote:Oh, and 14psi is boost cut on the stock ECU anyways.
There is no boost cut on these ECUs. The ECU would have to know the *boost* for that, and it doesn't have a MAP sensor. That cut is actually "airflow" cut. When the MAF output reaches its maximum of 5V, the ECU cannot determine the amount of airflow any more, which means it can't ensure safe engine operation, so it cuts the fuel. What boost this airflow limit is reached at, depends much on the turbo+setup.
