kim »
https://forums.nicoclub.com/kim-u15840.html
Tue Apr 27, 2004 9:44 pm
Hello,
I'm new to the boards, I just received a 1990 240sx for free. Only thing is the car had no engine and a broken trans. Well I put in a KA engine myself and an newer trans. I got the car started and it works but I'm having a few problems now.
First, the guy that owned the car before me almost emptied the Master and Slave Cylinders. So after I put in the engine and trans, I tried bleeding them today, but for some reason I don't get any pressure to the rear brakes? Every time I open the bleed valve, it doesn't let any pressure or fluid out? Do I need ot replace the Master cylinder?
Second, I rebuilt the clutch, I bleed it and it seems to be working fine but when I push the clutch all the way down to start the car, at that same level of pressing the clutch pedal I can't shift the trans in to any gear, but when I let go of the clutch a little then I can go in to gear. Whats the problem? It seems that if I push the clutch all the way down it won't let me get in to gear but if I pushi it just enough then it seems fine. Is this okay?
Any help would really be appricated! Thanks
